Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
DogBone Add-in
1 REPLY 1
Alexrose1942
243 Views, 1 Reply
DogBone Add-in
Hi
DogBone add-in doesn't appear although I followed instruction and added the folder under : c:\Users\xxy\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\Dogbone-master\
1 REPLY 1
marshaltu
in reply to: Alexrose1942
You can hit "+" button beside "My Add-Ins" in "Script & Add-Ins" dialog to add addin. You can select the folder "c:\Users\xxy\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\Dogbone-master\" to add the Dogbone addin.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
