Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Does Forge support .sldprt to .stl conversion?
0 REPLIES 0
Message 1 of 1
328 Views, 0 Replies
I am working on a project to convert .sldprt to .stl file types and I used Autodesk Fusion APIs to accomplish that on Windows. I want to do the same thing on Linux, however, Autodesk doesn't support Linux. So I am thinking of doing this via Forge and cURL. Before starting, I wanted to be sure whether Forge supports .sldprt to .stl conversion. I don't want to spend a lot of time on something that can not be accomplished.
Forge does support few file format conversions.
Tags (3)
0 REPLIES 0
