Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Does anyone have a better development workflow?
1 REPLY 1
chris.monachanZWSCF
266 Views, 1 Reply
I'm developing a complex add-in in C++ and I have to try it fairly frequently in fusion. I'm just wondering if there is a more efficient workflow than the one I'm using to test things. Given this is an excellent community I thought I'd ask.
Right now the steps are as follows:
1. Build add-in
2. In Fusion press SHIFT-S
3. Switch to the Add-In's tab
4. Run my Add-
5. Test it (I set the add-in to terminate on the OnDestory event, so I can build again without a sharing violation)
6. Change code
7. Goto 1.
I know these don't seem like many steps, but it would be perfect if I could get the Add-in's dialog to remember the last tab and stay on the Add-In tab where I have to click 20 times a day to run my Add-in, as it's not a script that's the default tab for that dialog everyt ime.
Better yet if I could somehow assign a hotkey to the add-in to just run it. I know I can assign a hotkey to my Command once my add-in is running but I still have to stop and re-run the add-in after every compile, to get to the point where my Command is shown (and hence can have a hotkey assigned).
Just wondering if anyone has a better workflow for development and testing of add-ins?
Labels (5)
1 REPLY 1
@chris.monachanZWSCF, like you, I wish I could assign shortcuts to my add-ins to run them. I hope the Fusion 360 team will make this possible in the future.
To make my life easier I control the creation of an add-in vs. a script by using a preprocessor in project properties and using #ifdef and #ifndef directives in destroy event handlers, run methods and stop methods of my add-ins. So during the development, I usually compile the add-in as a script.
for example I have somthing like the following code in my add-ins:
void XyzDestroyEventHandler::notify(const Ptr<CommandEventArgs>& eventArgs)
#ifndef ADDIN
	adsk::terminate();
#endif
Also during development, I use "type": "script" in the manifest and add my add-in to the scripts tab to save a click.
