Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
documentation bug: Document and Assembly Structure
3 REPLIES 3
s
Observer
764 Views, 3 Replies
The first python example on this page does not work (any more?):
app = adsk.core.Application.get()
ui = app.userInterface
design = adsk.fusion.Design(app.activeProduct) ### <<--- no constructor defined
if not design:
    ui.messageBox('No active Fusion 360 design', 'No Design')
    return
The line in the middle should probably be
design = adsk.fusion.Design.cast(app.activeProduct)
3 REPLIES 3
BrianEkins
in reply to: s
It's a mistake in the documentation. I'm fairly certain that I wrote that block of code in a text editor, along with the rest of that article, and not in an IDE. So it's my mistake and it should be using the cast property as you guessed.
Brian Ekins
Thanks for the reminder.
Brian Ekins
