Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
DistanceValueCommandInput's "expression" doesn't update after arrow dragging
1 REPLY 1
autodeskgato
216 Views, 1 Reply
I found a bug today in Fusion 360's API, while trying to read the expression property of a DistanceValueCommandInput. If you drag its blue arrow instead of setting a value in the text box, then the "expression" property is the one from immediately before it was dragged to its new position. The "value" property returns the correct result in centimeters, so it's easy to work around, just posting in case anyone runs into the same issue.
Example:
# Not working ( last value is used )
distance = adsk.core.ValueInput.createByReal(unitsMgr.evaluateExpression(input.expression, "cm"))
# Works
distance = adsk.core.ValueInput.createByReal(input.value)
1 REPLY 1
Justin.Krutz
in reply to: autodeskgato
I experienced this too. Thanks for finding a workaround!
