Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Display Part "PathName" in MessageBox
1 REPLY 1
isocam
192 Views, 1 Reply
Can anybody help?
Is it possible, using a Fusion 360 Script/AddIn to do the following:
Say I have a part open called "Bearing Housing" that is saved in a folder called "Purchased Parts"
Is it possible to display the parts path name using a fusion 360 scrip/Addin?
Example,
.....\Purchased Parts\Bearing Housing.f3d
Many thanks in advance!!!!
Darren
1 REPLY 1
marshaltu
in reply to: isocam
Please try the following codes and see if it meets your requirement.
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.activeDocument
        datafile = doc.dataFile
        path = datafile.name + '/' + doc.name
        datafolder = datafile.parentFolder
        while datafolder:
            path = datafolder.name + '/' + path
            datafolder = datafolder.parentFolder
        ui.messageBox('The path is \"{}\"'.format(path))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
