Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Directory structure, appropriate logs output directory, logs collection
3 REPLIES 3
jacob.r.jennings
334 Views, 3 Replies
When developing an AddIn in c++, where should I place logs files so they are included when collecting diagnostic logs via user-facing instructions: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How... ?
Can I get this directory via Application or UserInterface?
I believe a correct path might look like /Users/jakej/Library/Application Support/Autodesk/Autodesk Fusion 360/792RRXXHW5PV/logs
What does the UUID (792RRXXHW5PV in the path above) represent, a user?
Tags (3)
3 REPLIES 3
This is the User ID:
import adsk.core, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        user = app.currentUser
        ui.messageBox('{}\n{}\n{}\n{}'.format(user.displayName, user.email, user.userId, user.userName))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Tags (4)
It's good to know that directory represents the user. But, I still don't know where to place logs which may be collected by users during diagnostics
On Windows: C:\Users\<UserName>\AppData\Roaming
On Mac: /Users/<UserName>/Library/Application Support
Here is a code in Python to manage these folders:
import os
import platform
def getUserPreferencesFolder():
    preferencesPath = getPreferencesFolder()
    if not os.path.exists(preferencesPath):
        os.mkdir(preferencesPath)
    userPreferencesPath = os.path.join(preferencesPath, app.userId)
    if not os.path.exists(userPreferencesPath):
        os.mkdir(userPreferencesPath)
    return userPreferencesPath
def getPreferencesFolder():
    if platform.system() == 'Windows':
        preferencesPath = os.path.join(os.getenv('APPDATA'), '<YourAddinName>')
    else:
        preferencesPath = os.path.join(os.path.expanduser('~'), 'Library', 'Application Support', '<YourAddinName>')
    return preferencesPath
