Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Derive not showing as DocumentReference
2 REPLIES 2
sam.parsonsHHLF4
232 Views, 2 Replies
I'm trying to create a quick script that performs 'get all latest' in all of the fusion files in a folder. Annoyingly, derives don't seem to be recognised as referencedDocuments?
Any ideas why? And if I can't retrieve them as referencedDocuments, then how might I be able to perfom 'get all latest'?
Thanks in advance
2 REPLIES 2
helfenj
in reply to: sam.parsonsHHLF4
Hi Sam,
I'm sorry you're running into an issue. We are currently looking into a similar issue, would you be willing to share your design as it may help us locate the problem.
John
Product Manager - Fusion 360
sam.parsonsHHLF4
in reply to: helfenj
Thanks for getting back to me!
So it turns out that I can't get it to work with standard document references either. It seems to be the .getLatestVersion method that isn't doing what it should.
This is the original 'master file' that contained the derives:
https://a360.co/2PHGBap
Thanks again!
