Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Delete operations on "Timeline" space
1 REPLY 1
raterWBBQB
360 Views, 1 Reply
How do this using API?
1 REPLY 1
marshaltu
in reply to: raterWBBQB
You cannot delete operations directly from timeline. Instead you can delete corresponding features and then the item in timeline will be gone as well. The following codes demo how to delete the second extrude feature from timeline.
Marshal
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        extrude = adsk.fusion.ExtrudeFeature.cast(design.timeline.item(1).entity)
        extrude.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
