Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Default UI tree?
2 REPLIES 2
rbbauer00
218 Views, 2 Replies
Default UI tree?
I am trying to figure out how to put a button for my new command in a particular place in the UI.  The User guide suggests using the 'Write User Interface to File' sample script to get a list of all the UI objects.  However the script is broken.  Apparently the Fusion guys are aware (as of May 2020) but I don't see a fix available yet.  Is there a default list posted anywhere?  I've searched and came up empty handed, but may not be searching for the right thing.
I'd like to place my command in the Modify drop-down, somewhere between the bars that contain Shell and Silhouette Split.
R. Brad Bauer
2 REPLIES 2
OceanHydroAU
in reply to: rbbauer00
In case you missed it - I uploaded it in reply to your other posting here: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/example-script-write-user-interface-to-a-f...
rbbauer00
in reply to: OceanHydroAU
Thanks again.  Sorry for the duplicate post.
R. Brad Bauer
