Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
December 2020 Product Update - API "Export a Drawing as a PDF"
2 REPLIES 2
isocam
271 Views, 2 Replies
Can anybody help?
In the December 2020 Product Update, you can now using API, export a PDF file.
Can somebody at AutoDesk post a sample "script file" to show how to do this?
Many thanks in advance!!
Darren
2 REPLIES 2
kandennti
in reply to: isocam
BrianEkins
in reply to: isocam
Here's a script that will export the active drawing as PDF.
import adsk.core, adsk.drawing, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        drawing = adsk.drawing.Drawing.cast(app.activeProduct)
        if not drawing:
            ui.messageBox( 'A drawing must be active.')
            return
        exportMgr = drawing.exportManager
        exportOptions = exportMgr.createPDFExportOptions('C:/Temp/PDFExportText.pdf')
        exportOptions.sheetsToExport = adsk.drawing.PDFSheetsExport.AllPDFSheetsExport
        exportOptions.useLineWeights = True
        exportMgr.execute(exportOptions)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
