dataFiles.itemById() doesn't return a dataFile when versionId is passed as argument
sharas_s
sharas_s
Hello everyone,
I am trying to retrieve a specific version of a file. For this, I tried to take specific versions of a file using dataFile.versionId and later in the code I use that versionId string in dataFile.versions.ItemById() . According to documentation that should work and give back dataFile of the specific version, right?
kandennti
Hi @sharas_s .
I tried it too, but it didn't work.
Why don't you try to get the desired version of the DataFile from the versions property?
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9C14590B-1189-4A19-9438-3F6F2C9ABA85
Here is a sample to get the DataFile of the previous version of the active document.
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        # get active doc datafile
        doc = app.activeDocument
        dataFile: adsk.core.DataFile = doc.dataFile
        # get previous version datafile
        previousVersionDataFile = getPreviousVersionDataFile(dataFile)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getPreviousVersionDataFile(
    dataFile: adsk.core.DataFile) -> adsk.core.DataFile:
    currentVersion = dataFile.versionNumber
    if currentVersion < 2:
        return None
    dfs = [df for df in dataFile.versions if df.versionNumber == currentVersion - 1]
    if len(dfs) < 1:
        return None
    return dfs[0]
BrianEkins
I'm also able to reproduce this and it is a bug.  Hopefully, it can be fixed soon.  The workaround that @kandennti provided is a viable option until then.
Brian Ekins
sharas_s
Thanks for the suggestion @kandennti, that was my 1st way of retrieving different versions. Just in my case, the dataFile I am working on has a lot of versions (>1000). And going through versions to take a specific one takes quite some time (>10 min) when there are so many versions.
I made a workaround by saving the index of a specific version in dataFile.versions and later retrieving it using dataFile.versions.item(). This works fine for now, just dataFile.versions.itemById() would be more elegant.
Thanks @BrianEkins for confirming that this is a bug.
