Cutting multiple bodies with single tool body
cmcampbellNDCUJ
cmcampbellNDCUJ
I am looking for a way to cut all the bodies within a given component or assembly with a single tool body. The combine function will easily let me cut target bodies one at a time but in this case I'm looking to cut hundreds of target bodies with just a handful of tool bodies. Any help will be greatly appreciated.
kandennti
Hi @cmcampbellNDCUJ -San.
I have tried to create it, but since I have only tested it with simple data, errors may occur.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
import sys
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    "id": "kantoku_cutting_multiple_bodies_test",
    "name": "cutting multiple bodies test",
    "tooltip": "cutting multiple bodies test"
_targetOccIpt: core.SelectionCommandInput = None
_toolBodyIpt: core.SelectionCommandInput = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onValidateInputs = MyValidateInputsHandler()
            cmd.validateInputs.add(onValidateInputs)
            _handlers.append(onValidateInputs)
            onExecutePreview = MyExecutePreviewHandler()
            cmd.executePreview.add(onExecutePreview)
            _handlers.append(onExecutePreview)
            global _targetOccIpt
            _targetOccIpt = inputs.addSelectionInput(
                "_targetOccIptId",
                "Occurrences",
                "Select Target Occcurrence"
            _targetOccIpt.addSelectionFilter("Occurrences")
            _targetOccIpt.setSelectionLimits(1,)
            global _toolBodyIpt
            _toolBodyIpt = inputs.addSelectionInput(
                "_toolBodyIptId",
                "Tool Body",
                "Select Tool Body"
            _toolBodyIpt.addSelectionFilter("SolidBodies")
        except:
            _ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class MyExecutePreviewHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        occs = []
        for idx in range(_targetOccIpt.selectionCount):
            occs.append(_targetOccIpt.selection(idx).entity)
        global _toolBodyIpt
        exec_combines(
            occs,
            _toolBodyIpt.selection(0).entity
        args.isValidResult = True
def exec_combines(
        targetOccs: list[fusion.Occurrence],
        toolBody: fusion.BRepBody,
) -> None:
    try:
        bodies = get_occurrences_has_bodies(
            targetOccs,
            get_show_bodies(),
        if len(bodies) < 1: return
        exec_combine_diff(
            bodies,
            toolBody,
    except:
def exec_combine_diff(
        bodies: list[fusion.BRepBody],
) -> None:
    try:
        global _app
        des: fusion.Design = _app.activeProduct
        root: fusion.Component = des.rootComponent
        combFeats: fusion.CombineFeatures = root.features.combineFeatures
        for body in bodies:
            if body == toolBody: continue
            combIpt: fusion.CombineFeatureInput = combFeats.createInput(
                body,
                core.ObjectCollection.createWithArray(
                    [toolBody]
            combIpt.operation = fusion.FeatureOperations.CutFeatureOperation
            combIpt.isKeepToolBodies = True
            combFeats.add(combIpt)
        toolBody.isLightBulbOn = False
    except:
def get_occurrences_has_bodies(
) -> list[fusion.BRepBody]:
    bodyLst = []
    for body in bodies:
        if body.assemblyContext in targetOccs:
            bodyLst.append(body)
    return bodyLst
def get_show_bodies() -> list[fusion.BRepBody]:
    global _app
    showBodies = root.findBRepUsingPoint(
        core.Point3D.create(0,0,0),
        fusion.BRepEntityTypes.BRepBodyEntityType,
        sys.float_info.max,
        True,
    return list(showBodies)
class MyValidateInputsHandler(core.ValidateInputsEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.ValidateInputsEventArgs):
        if _targetOccIpt.selectionCount < 1:
            args.areInputsValid = False
            return
        global _toolBodyIpt
        if _toolBodyIpt.selectionCount < 1:
            return
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO["id"]
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO["id"],
                CMD_INFO["name"],
                CMD_INFO["tooltip"]
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
cmcampbellNDCUJ
Thanks @kandennti I'll give this a try and let you know how it goes.
cmcampbellNDCUJ
Hi @kandennti,
Your script worked perfectly!
Many thanks.
