Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
CustomFeatureDependencies.itemById throwing RuntimeError when key not found
1 REPLY 1
mcd8604
183 Views, 1 Reply
When I call CustomFeatureDependencies.itemById and pass an id that is not in the collection, I get the following runtime error:
RuntimeError: 3 : Invalid argument id
Based on the documentation, it was my understanding that this should fail gracefully and return null. This is ideal for a CustomFeature that has an optional dependency - i.e. it may or may not have been added and ActivateEdit is loading the dependencies. My current way of dealing with this is (but is not ideal)
try:
    dependency = editedCustomFeature.dependencies.itemById(id)
except:
    pass
1 REPLY 1
BrianEkins
in reply to: mcd8604
I'm able to reproduce the problem and will make sure a bug gets filed. Thanks for reporting this.
Brian Ekins
