Announcements
Custom workspace is not visible
m0d0
m0d0
Hi everyone,
I am trying to create a custom workspace. Using the minimal example below I would exspect a  new workspace to be created. The script runs without raising any errors but the workspace does not appear in the userinterface. You can access the workspace vai api by workspaces.itemById() but it is still not visible.
I already checked thisthis and this  post. However I can not spot any mistakes in my code.
I would realy appreciate any hints or a information in case it is currently not possible to create a custom workspaces.
# Author-
# Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
ws = None
tab = None
panel = None
cmd = None
ctrl = None
handlers = []
class MyCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        adsk.core.Application.get().userInterface.messageBox("created")
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        global ws
        global tab
        global panel
        global cmd
        global ctrl
        global handlers
        ws = ui.workspaces.add(
            app.activeProduct.productType, "verycustomworkspaceid", "my workspace", ""
        tab = ws.toolbarTabs.add("verycustomtoolbartabid", "my toolbar")
        panel = tab.toolbarPanels.add("verycustompanelid", "my panel")
        cmd = ui.commandDefinitions.addButtonDefinition(
            "verycustomcommandid", "my command", ""
        onCreated = MyCreatedHandler()
        cmd.commandCreated.add(onCreated)
        handlers.append(onCreated)
        ctrl = panel.controls.addCommand(cmd)
    except:
        if ui:
            ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        global ws
        global tab
        global panel
        global cmd
        cmd.deleteMe()
        ctrl.deleteMe()
        panel.deleteMe()
        tab.deleteMe()
        ws.deleteMe()
    except:
        if ui:
m0dd0
  • API
Replies (0)
