Custom UI with api
Custom UI with api
friesendrywall
Custom UI with api
friesendrywall
I am having a hard time grasping whether or not the api is capable of customizing the existing user interface with custom attributes.  In my case I would like to add a custom attribute to the CAM -> SETUP -> Post Process tab.  Is this possible with the API or not?
ekinsb
You can't modify the contents of the dialogs of other commands.  You can only define the contents of the dialogs for your own custom commands.
Brian Ekins
Mod the Machine blog
friesendrywall
Thank you, I sort of figured so, didn't feel like investing time without knowing.
