Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Custom GUI by API
2 REPLIES 2
taxponation
561 Views, 2 Replies
Custom GUI by API
I'm just wondering how to create customized GUI by Python or Javascript API. I want to create add-on like grasshopper in Rhinoceros and I need to implement a node editor with customized GUI.
My question is that it is possible or not and if so, how to make it?
Thanks in advance 🙂
2 REPLIES 2
ekinsb
in reply to: taxponation
The supported way of creating a GUI for a Fusion command is by creating a command and when it is executed you create command inputs which are then displayed in the command dialog to get the needed inputs from the user.  This definitely does limit what type of UI you can create.  No other method of creating a custom UI is currently supported, however there are some GUI libraries for Python that provide more capabilities.  But there are potential problems when using these including not working on both Windows and Mac and possibly having conflicts with Fusion itself.  I hope we'll have support for more GUI functionality in the future but there's nothing scheduled at the moment.
Brian Ekins
Mod the Machine blog
taxponation
in reply to: ekinsb
Thank you for your response. I see. I hope you will support more GUI tools soon.
