Hi @thomasa88 -San.
It is not just custom graphics, but you can do it by using preSelect, preSelectMouseMove, preSelectStart, etc.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-0550963a-ff63-4183-b0a7-a1bf0c99f821
The following sample uses SelectionCommandInput and PreSelectStart and PreSelectEnd to display the minimum and maximum coordinates of the BoundingBox when the mouse cursor hovers over the custom graphic mesh.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
"id": "kantoku_test",
"name": "test",
"tooltip": "test"
_selIpt: core.SelectionCommandInput = None
_txtIpt: core.TextBoxCommandInput = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandCreatedEventArgs):
core.Application.get().log(args.firingEvent.name)
try:
global _handlers
cmd: core.Command = core.Command.cast(args.command)
cmd.isOKButtonVisible = False
onDestroy = MyCommandDestroyHandler()
cmd.destroy.add(onDestroy)
_handlers.append(onDestroy)
onPreSelectStart = MyPreSelectStartHandler()
cmd.preSelectStart.add(onPreSelectStart)
_handlers.append(onPreSelectStart)
onPreSelectEnd = MyPreSelectEndHandler()
cmd.preSelectEnd.add(onPreSelectEnd)
_handlers.append(onPreSelectEnd)
inputs: core.CommandInputs = cmd.commandInputs
global _selIpt
_selIpt = inputs.addSelectionInput(
"selIptId",
"Hover to CustomGraphicsMesh",
_selIpt.isVisible = False
global _txtIpt
_txtIpt = inputs.addTextBoxCommandInput(
"txtIpt",
"CustomGraphicsMesh\n BoundingBox",
4,
True
except:
_ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class MyPreSelectStartHandler(core.SelectionEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.SelectionEventArgs):
args.isSelectable = False # not working
if args.selection.entity.classType() == fusion.CustomGraphicsMesh.classType():
cGMesh: fusion.CustomGraphicsMesh = args.selection.entity
bBox: core.BoundingBox3D = cGMesh.boundingBox
global _txtIpt
_txtIpt.text = f"Max{bBox.maxPoint.asArray()}\nMin{bBox.minPoint.asArray()}"
class MyPreSelectEndHandler(core.SelectionEventHandler):
def __init__(self):
super().__init__()
global _txtIpt
_txtIpt.text = "-"
class MyCommandDestroyHandler(core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandEventArgs):
adsk.terminate()
def run(context):
try:
global _app, _ui
_app = core.Application.get()
_ui = _app.userInterface
cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
CMD_INFO["id"]
if not cmdDef:
cmdDef = _ui.commandDefinitions.addButtonDefinition(
CMD_INFO["id"],
CMD_INFO["name"],
CMD_INFO["tooltip"]
global _handlers
onCommandCreated = MyCommandCreatedHandler()
cmdDef.commandCreated.add(onCommandCreated)
_handlers.append(onCommandCreated)
cmdDef.execute()
adsk.autoTerminate(False)
except:
if _ui:
