Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Custom Event Handler C++
3 REPLIES 3
jonathandent
286 Views, 3 Replies
I'm trying to edit a text box in my add-in,
I have created a worker thread that fires a custom event.
However, I can't seem to get an input ptr from anything to be able to get ahold of the text box ptr
I thought the below code would work...
Ptr<Event> firingEvent = eventArgs->firingEvent();
if (!firingEvent) {
return;
Ptr<Command> command = firingEvent->sender();
if (!command) {
return; <-- fails
Ptr<CommandInputs> inputs = command->commandInputs();
Is there a way to get to the input by using Ptr<UI>
Jonathan
Labels (1)
  • API
3 REPLIES 3
OceanHydroAU
in reply to: jonathandent
Hardly anyone uses C++
If you can, switching to Python would be an extrmely good idea.  Since you already know C++ - learning Python only takes a couple of days, and will greatly accelerate your development anyhow (so you save more than those days in the long run anyhow)
If you're stuck - go grab working examples and run from there - there's loads of "setup stuff" you can't guess from first principals...
jonathandent
in reply to: OceanHydroAU
That's not very helpful when the powers above make you code in c++ for this plugin/addin...
My Addin works fine single threaded blocking fusions main thread when its working. I just wanted it to feel better with a cancel worker thread option included.
Lucky enough I have a direct contact at AutoDesk, I'm just awaiting a response.
LaurinWeber
I know this is a really late reply but saying "hardly anyone uses c++" is not the answer people are looking for when explicitly asking for a cpp reference.
C++ so much faster and more optimized than python, so if i intend to make a highly complex programm and dont want my users to have to wait for some loadingbox i would recommend using C++ since it is very close to bare metal
There are numerous references that show how much faster C++ programms are compared to python
For example this one https://www.youtube.com/watch?v=3PcIJKd1PKU
Keep in mind that this is pure mathematics and doesnt even scratch the surface of the python interpreter boundries which is funnily written in C if i remember correctly
Mit freundlichen Grüßen
Laurin Weber
