Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
creating toolpaths from surfaces
1 REPLY 1
anthony.a.douglas
185 Views, 1 Reply
I am reading the documentation, but it is not clear it is possible to create toolpaths. Can I specify using an input object the various parameters and also certain surfaces as selected surfaces for machining, like the user can?  The documentation for the cam functionality seems to be way out of date.  It talks about 2016 and how things were back then, apparently with no updates since.  Is there better documentation somewhere?
1 REPLY 1
no? looking at the object model it doesn't look promising, but the documentation says you should be able to do nearly whatever a user can do.  I will have to use a keyboard macro or something as crude as that...
