Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Creating rigid groups from sub-components using the API
4 REPLIES 4
bungledb
248 Views, 4 Replies
Hi, Folks.
I'm struggling to wrap my head around operations with components that are children of components. Specifically, in this case, I want to make a rigid joint between two subcomponents from different parents.
Following this example, I can create a rigid group from components in the root component with no problem.
I can get it to work if things are all in the root and there are no sub-components involved:
root
+-comp1
+-subcomp1
+-comp2
--subcomp2
But it fails if I put the subcomponents one or more layers deeper, like this:
root
+ comp1
|   -subcomp1
- comp2
    -subcomp2
subcomp1 and subcomp2 are actually other models inserted into this one.
So this works:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    #Get system objects
    app = adsk.core.Application.get()
    project = app.data.activeProject
    design = adsk.fusion.Design.cast(app.activeProduct)
    root = design.rootComponent
    trans = adsk.core.Matrix3D.create()
    #Create top level components
    occ = root.occurrences.addNewComponent(trans)
    comp1 = occ.component
    comp1.name = 'comp1'
    comp2 = occ.component
    comp2.name = 'comp2'
    # Get folder containing other models
    for folder in project.rootFolder.dataFolders:
        if folder.name == "ExtComps":
            ext_folder = folder
    # Import each of the other models.
    for file in ext_folder.dataFiles:
        if file.name == 'Sphere':
            file_to_insert = file
            sub_comp1 = root.occurrences.addByInsert(file_to_insert, trans, True)
        elif file.name == 'Cube':
            sub_comp2 = root.occurrences.addByInsert(file_to_insert, trans, True)
    #Create a collection
    occs = adsk.core.ObjectCollection.create()
    occs.add(sub_comp1)
    occs.add(sub_comp2)
    #Create a rigid group.
    isIncludeChildren = True
    rigidGroups_ = root.rigidGroups
    rigidGroups_.add(occs, isIncludeChildren)
But this fails:
def run(context):
    #Get system objects
            ext_folder = folder
            sub_comp1 = comp1.occurrences.addByInsert(file_to_insert, trans, True)
            sub_comp2 = comp2.occurrences.addByInsert(file_to_insert, trans, True)
    occs.add(sub_comp1)
    occs.add(sub_comp2)
-> "RuntimeError: 5 : Provided input paths or alignments are not valid."
It inserts the external files just fine, but hits a wall when I try to create the rigid group. It also fails if I put both of the external objects under the same parent (eg comp1).
It's frustrating, because I can make exactly that rigid group using the GUI with no issues, so it's an allowed action, but I just can't see what I need to do in the API to achieve the same result.
Can anyone tell me what I've missed?
Labels (3)
4 REPLIES 4
kgrunawalt
in reply to: bungledb
To make the joint, you need two components that have full paths from root to component as context. I think the problem is that the two subcomponent objects are lacking that root-based occurrence path context.
I need to brush up on the api to be more specific!
bungledb
in reply to: kgrunawalt
Thanks, that helps. So I want to conceptually say "root/comp1/subcomp1," but my understanding of how to work contexts is shaky to say the least. 😕
Reading the docs again, it kind of feels like I should maybe use proxies - something like:
sc1proxy = sub_comp1.createForAssemblyContext(root)
sc2proxy = sub_comp2.createForAssemblyContext(root)
occs.add(sc1proxy)
occs.add(sc2proxy)
but that throws a Type Error of course because I need to put something more than the bare root component in createForAssembly(). Trouble is, I can't figure out what.
BrianEkins
You're very close.  Here's a slightly modified version of your program that works.
def run(context):
    #Get system objects
    occ1 = root.occurrences.addNewComponent(trans)
    comp1 = occ1.component
    occ2 = root.occurrences.addNewComponent(trans)
    comp2 = occ2.component
            ext_folder = folder
    # Import each of the other models. Because these are being created in the
    # context of the components, the occurrences returned are also in that context.
    # This then creates proxies for the occurrences that are relative to root.
            sub_occ1 = comp1.occurrences.addByInsert(file_to_insert, trans, True)
            sub_occ1 = sub_occ1.createForAssemblyContext(occ1)
            sub_occ2 = comp2.occurrences.addByInsert(file_to_insert, trans, True)
            sub_occ2 = sub_occ2.createForAssemblyContext(occ2)
    occs.add(sub_occ1)
    occs.add(sub_occ2)
Brian Ekins
bungledb
in reply to: BrianEkins
Aaahh! The light bulb just came on over my head.
Thank you so much, @BrianEkins, that's great.
