Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Creating new setups from API
4 REPLIES 4
emailGS28V
311 Views, 4 Replies
Hello, is there a way to create a new setup from API? I have a model, where I have to repeatedly create a lot of setups and I would like to automate the process. However, looking at [1] I don's see a way to create a setup. Am I correct? If so, is extending the CAM API on a roadmap?
[1] http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-56F7F035-883E-480F-8887-9A6679305346
4 REPLIES 4
goyals
in reply to: emailGS28V
I am not sure how much functionality is exposed through CAM API but here is the documentation link for API http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7F3F9D48-ED88-451A-907C-82EAE67DEA93
Shyam Goyal
Sr. Software Dev. Manager
BrianEkins
in reply to: goyals
it's currently not possible to create a CAM setup through the API.  You can only access existing setups.
Brian Ekins
emailGS28V
in reply to: BrianEkins
And is extending the CAM API on a roadmap? Or is there a workaround? I want to create a setup for each component in the model and make the Z-axis perpendicular to the largest face on the component.
emailGS28V
Hello, has anything changed in the past 2 years regarding creating new setups in Fusion?
