Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Creating custom threads using Sweeps or other tools
2 REPLIES 2
jphalip
130 Views, 2 Replies
I'd like to write a script that creates custom, non-standard threads. I believe the common tool for that is the Coil. However, I've learned from past experience that Coils can only be controlled in scripts via Text Commands, which can lead to some issues.
So I was thinking perhaps the Sweep tool could be used instead? Do you think that would be possible, and if so, do you have any tips on how to do it? Or should I consider a different tool altogether?
Julien
2 REPLIES 2
kandennti
in reply to: jphalip
Hi @jphalip .
The numbers are appropriate, but I made a sample.
The helix uses the TemporaryBRepManager.createHelixWire method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-19CBF605-BB13-4FB6-84CC-F92C0CC7F3BE
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        exec_sample()
        app.activeViewport.refresh()
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exec_sample():
    des: fusion.Design = app.activeProduct
    root: fusion.Component = des.rootComponent
    helix: fusion.SketchFixedSpline = create_helix(
        root,
        core.Point3D.create(0.0,0),
        core.Vector3D.create(0,0,1),
        core.Point3D.create(2,0,0),
        1,
        5,
        0,
    sktPlane: fusion.ConstructionPlane = create_plane(root, helix)
    guideRail: fusion.SketchFixedSpline = create_helix(
        root,
        core.Point3D.create(0,0,0),
        core.Point3D.create(1,0,0),
        1,
        5,
        0,
    profile: fusion.Profile = create_profile_sketch(
        root,
        sktPlane,
            core.Point3D.create(-0.5,0.2,0),
            core.Point3D.create(-0.5,-0.2,0),
    create_guide_rail_sweep(
        root,
        profile,
        helix,
        guideRail,
def create_guide_rail_sweep(
    comp: fusion.Component,
    profile: fusion.Profile,
    pathCurve: fusion.SketchFixedSpline,
    guideCurve: fusion.SketchFixedSpline,
) -> fusion.SweepFeature:
    path: fusion.Path = fusion.Path.create(
        pathCurve,
        fusion.ChainedCurveOptions.noChainedCurves
    guide: fusion.Path = fusion.Path.create(
        guideCurve,
    sweepFeats: fusion.SweepFeatures = comp.features.sweepFeatures
    sweepIpt: fusion.SweepFeatureInput = sweepFeats.createInput(
        profile,
        path,
        fusion.FeatureOperations.NewBodyFeatureOperation
    sweepIpt.guideRail = guide
    return sweepFeats.add(sweepIpt)
def create_profile_sketch(
    plane: fusion.ConstructionPlane,
    pointList: list,
) -> fusion.Profile:
    skt: fusion.Sketch = comp.sketches.add(plane)
    skt.isLightBulbOn = False
    points: fusion.SketchPoints = skt.sketchPoints
    sktPnts = [points.add(p) for p in pointList]
    sktPnts.append(sktPnts[0])
    sktLines: fusion.SketchLines = skt.sketchCurves.sketchLines
    for p1, p2 in zip(sktPnts, sktPnts[1:]):
        sktLines.addByTwoPoints(p1, p2)
    return skt.profiles[0]
def create_plane(
    curve: fusion.SketchFixedSpline,
) -> fusion.ConstructionPlane:
        curve,
    planes: fusion.ConstructionPlanes = comp.constructionPlanes
    planeIpt: fusion.ConstructionPlaneInput = planes.createInput()
    planeIpt.setByDistanceOnPath(
        path,
        core.ValueInput.createByReal(0),
    plane: fusion.ConstructionPlane = planes.add(planeIpt)
    plane.isLightBulbOn = False
    return plane
def create_helix(
    axisPoint: core.Point3D,
    axisVector: core.Vector3D,
    startPoint: core.Point3D,
    pitch: float,
    turns: float,
    taperAngle: float,
) -> fusion.SketchFixedSpline:
    tmpMgr: fusion.TemporaryBRepManager=fusion.TemporaryBRepManager.get()
    helixWireBody: fusion.BRepBody = tmpMgr.createHelixWire(
        axisPoint,
        axisVector,
        startPoint,
        pitch,
        turns,
        taperAngle,
    skt: fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    sktFixeds: fusion.SketchFixedSplines = skt.sketchCurves.sketchFixedSplines
    return sktFixeds.addByNurbsCurve(helixWireBody.wires[0].edges[0].geometry)
It is indeed cumbersome.
jphalip
Hi @kandennti -- thank you so much for taking the time. I haven't had a chance to try this yet, but will hopefully do so soon and report back.
