Announcements
Creating a custom thread
I'm trying to create a custom Square thread and have followed the instructions on how to create an xml file.
Here is an example of the xml I made.  It works when I do an external thread but when doing an internal thread , nothing changes.  No thread shows in the drawing.  Photo is below also.  Appreciate any help.
Thread is a square thread , 10 deg wall angle, 4 TPI.  Depth is only .031 instead of standard P/2 depth
<?xml version="1.0" encoding="UTF-8"?>
<ThreadType>
<ThreadForm>5</ThreadForm>
<Name>SQUARE Screw Threads</Name>
<CustomName>SQUARE Screw Threads</CustomName>
<Unit>in</Unit>
<Angle>10</Angle>
<SortOrder>15</SortOrder>
<ThreadSize>
<Size>1417</Size>
<Designation>
<ThreadDesignation>2.655</ThreadDesignation>
<CTD>2.655</CTD>
<TPI>4</TPI>
<Thread>
<Gender>external</Gender>
<Class>2G</Class>
<MajorDia>2.651</MajorDia>
<PitchDia>2.618</PitchDia>
<MinorDia>2.596</MinorDia>
</Thread>
<Thread>
<Gender>internal</Gender>
<Class>2G</Class>
<MajorDia>2.658</MajorDia>
<PitchDia>2.622</PitchDia>
<MinorDia>2.604</MinorDia>
</Thread>
</Designation>
</ThreadSize>
</ThreadType>
HughesTooling
I've reported this bug here. By the way really you need to use a trapezoidal thread but that has a bug too and creates an incorrect formSmiley Sad
If you change the form to 0 it generates a thread just to the wrong form, this bug also shows up with the built in metric trapezoidal threads.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks Mark for testing it and reporting the bug. I hope they are able to fix it.
