Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
creating a building pattern
1 REPLY 1
adamlandstrm
327 Views, 1 Reply
hi i made this tower of triangles created by copy pasting the previous peace rotating 2.5 degrees and moving it up 2mm.
my question is can I automate this pattern I manually need to do for each piece?
is there a function that allows me to set a pattern where I can choose x amount of components laying x away from each other in X,Y or Z direction and rotating x amount of degrees from the component previous in the pattern? and that I can go back to and change the values for not having to do so for each and every piece
1 REPLY 1
Can you please refer the solution in the below post which shows copying multiple times of a selected body in model X direction :
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/paste-a-body-from-clipboard/td-p/5594136
Also, please refer the solution of the post which demonstrates the rotation of selected body by 45 degrees around the model X axis and then 45 degrees around the model Y axis :
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/is-it-possible-to-rotate-a-body-by-multipl...
