Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create void body from a 3D model
2 REPLIES 2
Ray.bongalon
135 Views, 2 Replies
Hi. I have this mechanical model that I need to get the rough volume. Is it possible to create a void body from the model's external face? I tried 'Body Fill' but I can't make it work. My last option is to create cross-section sketches (ignoring the cleats, bolts, etc) of the shaft and extrude them. Thank you all.
2 REPLIES 2
BrianEkins
in reply to: Ray.bongalon
There's not an easy way that I know of. You can use commands in the SURFACE tab so that you can delete faces, and then you can patch the openings and stitch it back together as a solid that won't have any of the internal cavities. For example, look at a simple pipe. If you delete the two faces on the ends of the pipe, you'll end up with two cylindrical faces. Now, if you patch the openings only using the larger cylindrical faces and stitch the three surfaces together, you'll have a solid cylinder using the larger of the two cylindrical faces. It's the same idea for a more complex model.
Brian Ekins
Ray.bongalon
Hi Brian,
Thank you for getting back to me. I'll look into this process.
Regards
