create text area and align text - do with API like in UI
info83PHN
info83PHN
When working in the UI, I can add text to a Sketch, by dragging the text area.
Text in the text area can then be aligned center ( horizontally ) and aligned 'middle' ( vertically ).
This is very useful to center the text content on another item or rectangle.
In the API, I can create a box, create a circle, but the text seems to only have a starting point ( the bottom left point of the auto-sizing text area, depending on it's text content )
Is there a way to replicate the UI method of creating a specific size text box ?
# draw box1
        uPointA = adsk.core.Point3D.create(uNextBoxX, uNextBoxY, 0)
        uPointB = adsk.core.Point3D.create(uNextBoxX+uBoxW, uNextBoxY-uBoxH, 0)
        sketch.sketchCurves.sketchLines.addTwoPointRectangle(uPointA, uPointB)
# draw circle1
        circles = sketch.sketchCurves.sketchCircles
        circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(uNextBoxX+uCircleX, uNextBoxY-uCircleY, 0), uCircleDiam*0.5)
# Create sketch text input starting point
        uFont = "Segoe UI Semilight"
        point = adsk.core.Point3D.create(uNextBoxX, uNextBoxY, 0)
        sketchTexts = sketch.sketchTexts
        sketchTextInput = sketchTexts.createInput("SAMPLE CODE", uTxHeight, point)
        sketchTextInput.fontName = uFont
        sketchText = sketchTexts.add(sketchTextInput)
tykapl.breuil
You can use the setAsMultiline method as seen in the text sample :
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a611130a-a957-11e5-ac5a-f8b156d7cd97
Since you define both diagonal points, you have access to the center point and can use that to position your sketch. And, using this method, you can define the alignements.
info83PHN
Thanks a LOT - this is EXACTLY what I was looking for.
