Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create Component From MeshBody?
6 REPLIES 6
Joshua.mursic
286 Views, 6 Replies
Hello, is it possible to create a component from a mesh body after the mesh has been inserted into the project? I know that you can use,  something like this:
newComponent = root.occurrences.addNewComponent(adsk.core.Matrix3D.create())
newComponent.component.meshBodies.add()
it insert a mesh from a file. But is there a way to target a mesh in the design environment and create a component from it? Like with a BRepBody?
adsk.fusion.BRepBody.createComponent()
6 REPLIES 6
BrianEkins
in reply to: Joshua.mursic
The API doesn't directly support this, but a simple workaround exists. Because the "Create Components from Bodies" doesn't have a dialog, you can use the command. Here's an example that creates a new component using the first mesh body in the root component.
meshBody = des.rootComponent.meshBodies[0]
ui.activeSelections.add(meshBody)
cmd = ui.commandDefinitions.itemById('FusionCreateNewCompCmdFromBody')
cmd.execute()
Brian Ekins
Joshua.mursic
in reply to: BrianEkins
Amazing, thank you very much
Joshua.mursic
Hey @BrianEkins, I've run into an issue where when I call this function and then try to target the resulting component, I am unable to, because it dose not exist yet.
meshBody = design.rootComponent.meshBodies[0]
cmd = ui.commandDefinitions.itemById(u'FusionCreateNewCompCmdFromBody')
executed = cmd.execute()
while executed is False:
    pass
newComp = root.occurrences.item(root.occurrences.count-1)
I've tried making a while loop until the command returns that it was successful but that isn't working.
Joshua.mursic
I tried creating a handler to let me know when the command terminated but my handler is never firing. Which suggests that the command is never being fired? I'm really at a loss for how to proceed.
import adsk.core, adsk.fusion, adsk.cam
app = adsk.core.Application.get()
ui = app.userInterface
local_handlers = []
def run():
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    root = design.rootComponent
    # Add handler
    onCommandTerminated = MyCommandTerminatedHandler()
    ui.commandTerminated.add(onCommandTerminated)
    local_handlers.append(onCommandTerminated)
    # Run the command
    meshBody = root.meshBodies.item(0)
    cmd.execute()
# Event handler for the commandTerminated event.
class MyCommandTerminatedHandler(adsk.core.ApplicationCommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        event_args = adsk.core.ApplicationCommandEventArgs.cast(args)
        if event_args.commandId == "FusionCreateNewCompCmdFromBody":
            ui.messageBox("Component Created")
kandennti
Hi @Joshua.mursic .
The CommandDefinition.execute method is processed together after the script is finished, so in this case it is executed after the local_handlers are released.
At this time, we have not found a way to invoke other commands during processing other than using text commands.
        # Run the command
        meshBody: adsk.fusion.MeshBody = root.meshBodies.item(0)
        # cmd = ui.commandDefinitions.itemById('FusionCreateNewCompCmdFromBody')
        # cmd.execute()
        app.executeTextCommand(u'Commands.Start FusionCreateNewCompCmdFromBody')
Joshua.mursic
in reply to: kandennti
Thank you this is exactly the issue. Much appreciated @kandennti
