Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create component & get ID
2 REPLIES 2
lukepighetti
281 Views, 2 Replies
Hi there,
How do I create a component and get the ID for it?
Luke
2 REPLIES 2
ekinsb
in reply to: lukepighetti
I'm not sure what you mean by "ID" but each component does have a name which you can see and edit in the browser.  That's exposed in the API through the name property of the Component object.
Brian Ekins
Mod the Machine blog
I know it's really old but I landed here looking for the same answer.
// Get the root component of the active design.
var rootComponent = design.rootComponent;
// Create a new occurrence.
var trans = adsk.core.Matrix3D.create();
var newOccurrence = rootComponent.occurrences.addNewComponent(trans);
// Get the associated component.
var newComponent = newOccurrence.component;
// get the name
var newComponentName = newComponent.name
// and message the new component name
ui.messageBox('New component name is: ' + newComponentName);
