Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create circle using 3 points via script
8 REPLIES 8
Message 1 of 9
fredrikcarlssonnlm
392 Views, 8 Replies
Hey
We want to create a circle using 3 points in a 3 dimensional space using scrips in Fusion360.
I dont find any fucntion for this.
There is alot of functions to create circles but not to create a circle from 3 points.
Br
Fredrik
8 REPLIES 8
Message 2 of 9
Hi @fredrikcarlssonnlm -San.
Try using the addByThreePoints method.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        skt: fusion.Sketch = root.sketches.add(
            root.xYConstructionPlane
        skt.sketchCurves.sketchCircles.addByThreePoints(
            core.Point3D.create(1,0,0),
            core.Point3D.create(2,1,2),
            core.Point3D.create(0,1,-1),
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Message 3 of 9
Have you tried this function?
Seems to be coming directly from ChatGPT?
We do not get this to work currently and have already tries this sadly.
Message 4 of 9
It is running fine in my environment.
Fusion360 Ver2.0.18719
ms_python v2023.20.0
Message 5 of 9
BrianEkins
in reply to: kandennti
addByThreePoints is not a method imagined by ChatGPT. Here's the official Fusion documentation for it.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-bb94f635-2b1f-4ee2-ad64-dc2418a8584a
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Message 6 of 9
Thanks!
I will try this directly!
Message 7 of 9
Does this work with 3 dimensional points?
All the points are on the same construction plane but they dont have the same x,y or z cordinate.
Message 8 of 9
If there are three points in a straight line, you will probably get an error, but otherwise it is fine.
Message 9 of 9
BrianEkins
It does work in 3D space. It uses the coordinate system of the sketch. All sketches are 3D; it's just that we usually only draw on their X-Y plane, but they support geometry that exists outside that plane.
If your coordinates are with respect to model space, you can use the Sketch.modelToSketchSpace method to convert the model space coordinates into sketch space coordinates and then use themto create your circle.
Brian Ekins
