Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create array with id bRepFaces and save it in model fusion 360
3 REPLIES 3
VitautTryputsin
338 Views, 3 Replies
Hello. I need create array with ID bRepFaces and save it in model fusion 360. It is need to call this array later, and to get ID's if even
Fusion 360 will be reopened. What kinds of way to realize it? Can I add attributes to bRepFaces?
3 REPLIES 3
ekinsb
in reply to: VitautTryputsin
Entities don't have a persistent ID, so there's nothing to save.  The only exception to that are things that have a name, like features and joints, but they can be renamed by the user so the name isn't completely reliable.  However, with the update that's going out today, Fusion now supports attributes.  Attributes let you add information to any entity, include B-Rep entities.  With this you can add an attribute to any face you want to find later so it should let you accomplish what you're trying to do.  There's a section in the updated help that will also go out later today about attributes. I've already uploaded the chm version that you can access here: https://autodesk.box.com/s/qlfca7dnmozhcvytc2ljh0nktnh23yk2
Brian Ekins
Mod the Machine blog
MattWynn
in reply to: ekinsb
looking forward to trying attributes
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
Thank you for a detailed explanation
