Create an Assembly using the Fusion 360 API
maryanneF5NKN
maryanneF5NKN
I am developing a Fusion 360 Add-in, where I need to create assemblies using the API, but I cannot find the relevant parts of the API for assemblies.
My goal state is to implement a script which results in the output described by the attached image.
I currently do not know:
- The object name which implements the Assembly functionality
- Where the documentation for this is
- How to create an assembly
- How to add a component to a assembly
Is it possible to get a script example/sample for creating a assemblies and nested assemblies? Also, documentation links would be helpful if you have any.
Kind Regards,
Maryanne
BrianEkins
I believe most of your questions are answered by this help topic.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-88A4DB43-CFDD-4CFF-B124-7EE67915A07A
It also includes a small snippet of code that will create a new occurrence.  To create nested occurrences you just keep adding occurrences within the newly created component.
Brian Ekins
