Create a Template from a operation using Fusion 360 Python API
enervino
enervino
I am not sure what I am doing wrong but I cannot seem to export Templates from operations for fusion using the API.
Here is the script I am trying:
import adsk.core, adsk.fusion, adsk.cam
def save_template():
    # Get the application
    app = adsk.core.Application.get()
    # Get the active document
    doc = app.activeDocument
    # From the Products collection on the active document, get the CAM Product
    cam :adsk.cam.CAM = doc.products.itemByProductType('CAMProductType')
    # Get the first setup.
    setup = cam.setups.item(0)
    # Get the first operation.
    operation = setup.operations.item(0)
    # generate the Cam Template
    returnValue = adsk.cam.CAMTemplate.createFromOperations(operation)
    # Save the template to a file
    returnValue.save('C:\\file.camtemplate')  # Change this to your desired file path
# Call the function
save_template()
I am trying to use the CAMTemplate Object to generate templates.
I was also trying to give it a operation list but then Fusion just fully cashed with no error.
jeff.pek
Hi -
CAMTemplate.createFromOperations takes a list of operations, so you need to pass it as "[operation]".
Jeff
enervino
OK here is the changes I made, Seems to work now thanks, I think I was having issues with separating setup.operations and a list of operation
        #create a list of operations then add an operation to it
        operations = []
        operations.append(operation)
        returnValue = adsk.cam.CAMTemplate.createFromOperations(operations)
        returnValue.save('C:\\c#\\#python\\1Test\\file.f3dhsm-template')  # Change this to your desired file path
jeff.pek
Sure, that works. It would be even easier to just put square brackets around the "operation" argument in the call, but what you have does the equivalent.
Jeff
enervino
I am not too familiar with Python syntax, it is all a bit strange to me. anyway, it seems if you put something the API does not like into returnValue.save('here') like an invalid directory or an existing file name, then fusion full crashes without warning, so sanitize that input (fusion should probably wanna look into this too because you would expect an exception throw there, not a full crash)
jeff.pek
Agreed. Thanks for pointing that out.
  Jeff
