Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create a spline by setting the length between to fit points
2 REPLIES 2
ione_ianniruberto
181 Views, 2 Replies
Hi everyone,
I have a problem. I want to create a spline using this code:
        design = adsk.fusion.Design.cast(app.activeProduct)
        Features = adsk.fusion.Features.cast(app.activeProduct)
        rootComp = design.rootComponent
        points = adsk.core.ObjectCollection.create()
        points.add(adsk.core.Point3D.create(0, 0, 0))
        points.add(adsk.core.Point3D.create(10, 20, 30))
        points.add(adsk.core.Point3D.create(20, 40, 60))
        points.add(adsk.core.Point3D.create(30, 60, 90))
        sketchnurb = rootComp.sketches.add(rootComp.xYConstructionPlane)
        spline = sketchnurb.sketchCurves.sketchFittedSplines.add(points)
But then i want to set the length of the spline between to consecutive points to a specific value. How can I do?
Thanks so much
2 REPLIES 2
There isn't a way to specify the length of the spline. The only way to control the length is to modify the position of the fit points. The closer they are to a straight line, the closer the length of the spline will be to a line that goes directly between the two endpoints. Moving the intermediate points will cause the length to be longer. It would be trial and error to get a specific length.
Brian Ekins
Ok, thanks for your answer
