create a series of pipes along mesh
Ok I found a way to reproduce a mesh i import into fusion, stl or obj file, by simply taking get mesh section, fit curve to mesh section using closed spline set to .09 inches and then making a circular pipe on the final curve made. Now to do this i select a mesh and rotate it around the optimal, fewest number of of lines made in the mesh selection, axis. Thing is it takes for ever and i lose count in the degrees i am at. can any one help me find a way to create a script or add-on that can reproduce my method once i select my mesh. any one able to help me find the python snipers in the data base so i can make this happen and make this overly repetitive task a mater of clicks and not a rinse, repeat, since, repeat.... technique?
Replies (0)
