Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Create a 2D-operation and set the tool orientation over API
2 REPLIES 2
maurizio_manzi
206 Views, 2 Replies
It is now possible, for example, to insert a pocket operation via the API and to select various parameters including geometry via the API. Is it also possible to set the complete tool orientation via the API (see image)? Does anyone have an example?
Best regards
Maurizio
2 REPLIES 2
Hi @maurizio_manzi
Here is the little snippet of codes you can implement in your code
#operation creation
opInput = setup.operations.createInput('pocket2d')
opInput.tool = getTool()
# Enable Tool orientation
opInput.parameters.itemByName('overrideToolView').expression = 'true'
opInput.parameters.itemByName('view_orientation_mode').expression = "'axesZX'" ## Setting tool orentation mode to select Z axis/plane & X axis
opInput.parameters.itemByName('view_orientation_flipZ').expression = 'true'
#Adding the operation
pocketOp = setup.operations.add(opInput)
edge = body.edges.item(0) ## Body is a brepbody
pocketFace = body.faces.item(0)
## seleting my edge for Z Axis
toolAxis: adsk.cam.CadObjectParameterValue = pocketOp.parameters.itemByName("view_orientation_axisZ").value
toolAxis.value = [edge]
## Select a face for pocket
pocketSelection: adsk.cam.CadContours2dParameterValue = pocketOp.parameters.itemByName("pockets").value
faces = pocketSelection.getCurveSelections()
face_ = faces.createNewPocketSelection()
face_.inputGeometry = [pocketFace]
pocketSelection.applyCurveSelections(faces)
Boopathi Sivakumar
Senior Technology Consultant
Thank you very much
