Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Crash extruding to Construction Plane
3 REPLIES 3
chris.monachanZWSCF
319 Views, 3 Replies
I have a consistent crash when trying to extrude a profile to a construction plane where the construction plane is given as a ToEntityExtentDefinition in setOneSideExtent in the ExtrudeFeatureInput.
I don't have code to hand but if people can't reproduce I can put some together. Basically I've tried everyway and it always crashes. In the UI this operation works fine, but not through the API.
As a work-a-round I now create a temp body, extrude to that face and then get rid of the body. This seems like an easy fix to me as it's a crash and should be fairly simple to see what's going on if you have the Fusion source in-front of you when it crashes.
BTW in my case, this is in parametric design mode and the target plane and the source sketch profile are at angles.
Labels (5)
3 REPLIES 3
Hi @chris.monachanZWSCF .
I made a sample that looks like this.
It did indeed crash. (Fusion360 ver2.0.10564)
# Fusion360API Python script
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        # create Plane
        sktPlane: adsk.fusion.ConstructionPlane = initPlane(
            root,
            [1,2,3],
            [3,2,1],
            [2,3,1],
        # create Plane
        targetPlane: adsk.fusion.ConstructionPlane = initPlane(
            root,
            [5,6,4],
            [7,6,5],
            [4,5,7],
        # create Sketch
        skt: adsk.fusion.Sketch = initSketchCircle(sktPlane, [1,2,0], 1)
        # create ExtrudeFeature
        exts: adsk.fusion.ExtrudeFeatures = root.features.extrudeFeatures
        extIpt: adsk.fusion.ExtrudeFeatureInput = exts.createInput(
            skt.profiles[0],
            adsk.fusion.FeatureOperations.NewBodyFeatureOperation
        TOENTITY = adsk.fusion.ToEntityExtentDefinition
        ent: adsk.fusion.ToEntityExtentDefinition = TOENTITY.create(targetPlane, True)
        extIpt.setOneSideExtent(ent, adsk.fusion.ExtentDirections.PositiveExtentDirection)
        exts.add(extIpt) # <- Crash
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def initSketchCircle(
    plane: adsk.fusion.ConstructionPlane,
    center: list,
    radius: float) -> adsk.fusion.Sketch:
    comp: adsk.fusion.Component = plane.parent
    skt: adsk.fusion.Sketch = comp.sketches.add(plane)
    circles: adsk.fusion.SketchCircles = skt.sketchCurves.sketchCircles
    circles.addByCenterRadius(
        adsk.core.Point3D.create(center[0],center[1],center[2]),
        radius)
    return skt
def initPlane(
    comp: adsk.fusion.Component,
    ary1: list,
    ary2: list,
    ary3: list,
    ) -> adsk.fusion.ConstructionPlane:
    skt: adsk.fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    skt.isLightBulbOn = False
    pnts: adsk.fusion.SketchPoints = skt.sketchPoints
    PNT3D = adsk.core.Point3D
    [pnts.add(PNT3D.create(v[0],v[1],v[2])) for v in [ary1,ary2,ary3]]
    planes: adsk.fusion.ConstructionPlanes = comp.constructionPlanes
    planeIpt: adsk.fusion.ConstructionPlaneInput = planes.createInput()
    planeIpt.setByThreePoints(
        skt.sketchPoints[1],
        skt.sketchPoints[2],
        skt.sketchPoints[3]
    return planes.add(planeIpt)
BrianEkins
in reply to: kandennti
I can also reproduce the problem and a bug has been logged.
Brian Ekins
Hey, thanks for putting the time in to construct a repro. I work in C++ and on a complex Fusion Add-In project so it's often difficult for me to pull out individual bits of code.
Technology Administrators
