Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Copy drawing and 3d model
2 REPLIES 2
ianjwellings
164 Views, 2 Replies
I'm looking to save a copy of an existing drawing and 3d model, and for the new drawing to be linked to the new 3d model.  I noticed there have been a few posts dated back to 2017 and that there's a workaround by sharing a download link and then downloading the f3z file from Fusion Teams, uploading the file and the  renaming. However I'm hoping to automate the process using the API, so that I can then edit user parameters on the new 3d model and drawing. Does the API allow you to copy the drawing and create the link to the new model, or replace the link somehow?
2 REPLIES 2
BrianEkins
in reply to: ianjwellings
There isn't any support for this now. Currently, the API has very little support for any drawings-related functionality.
Brian Ekins
ianjwellings
in reply to: BrianEkins
Hi Brian,
Thanks for confirming. I will use the workaround using an f3z file.
