Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Convert value to fractional inch
2 REPLIES 2
thomasa88
192 Views, 2 Replies
Hi, the following function can convert values between different units:
adsk.core.Application.get().activeProduct.fusionUnitsManager.convert(2.54, "cm", "inch")
That works well, but now I want to convert a value to a fractional inch, say 3.25" to 3 1/4". How can I do that?
2 REPLIES 2
JeromeBriot
in reply to: thomasa88
I don't know if something exists in the API, but in Python you can do this:
import fractions
val_dec = 3.25
val_frac = fractions.Fraction(val_dec)
print("{} {}".format(int(val_dec), val_frac % 1))
BrianEkins
in reply to: JeromeBriot
I can confirm that there is nothing in the API to get fractions.  Thanks to @JeromeBriot for pointing out there is something in the Python library.  I wasn't aware of that.
Brian Ekins
