Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Convert Toolpath or G-Code to Geometry
5 REPLIES 5
Jay.Perez
706 Views, 5 Replies
Does anyone know of a feature or function in Fusion that will allow me to convert or export a toolpath or its g-code to some type of vector geometry ?   I only need the flat 2D info so if it also stripped out the extraneous moves and code that would be fantastic !
Thanks in advance for any help or suggestions.
Jay
5 REPLIES 5
al.whatmough
in reply to: Jay.Perez
We have a Dxf Post you can use for this.
You can even choose to only output cutting moves.
https://cam.autodesk.com/hsmposts?p=dxf
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Jay.Perez
in reply to: al.whatmough
Sweet !!!
Thank you so much for the quick reply and the painless solution !
Jay
Muchísimas Gracias, funciona perfectamente.
ClintNicely
Any chance there is a functionality that does this for 3D Gcode?
Thank you!
al.whatmough
in reply to: ClintNicely
there is a dxf post processor that might work for you.
AL Whatmough
