Convert Mass from internal units to user units
ebunn3
ebunn3
Is there a way to change this line of code to work for mass units?  For example converting kg to lbmass?   I can determine how to do it for length units but not mass units.
Eric
convertVal = design.unitsManager.convert(val, design.unitsManager.internalUnits,design.unitsManager.defaultLengthUnits )
kandennti
Hi @ebunn3 .
I tried it, and was able to convert.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        value = 1
        kg = des.unitsManager.formatUnits('kg')
        lbm = des.unitsManager.formatUnits('lbmass')
        res = des.unitsManager.convert(
            value,
            kg,
            lbm,
        ui.messageBox(f'{value} {kg} -> {res} {lbm}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It seems to be possible to convert directly by using a string as a parameter.
            value,
            'kg',
            'lbmass',
BrianEkins
In the user interface, the only setting available to the user is to set the active unit for the distance, as shown below. That's the reason the API only exposes that setting.
However, I just noticed that other units types are changed based on that setting.  For example, below are various settings for the distance and the unit type that mass is reported in.  It seems like it would be best to give the user the choice of their mass unit instead of tying it to the length but that's what it does today. Because of the current behavior, it would be useful for the API to expose this but you can also have your own table so you know what units to associate with the current active length.
Inch - Ounces
Feet - Pounds
Centimeter - Grams
Meter - Kilograms
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
ebunn3
Thanks for the clarity.   I can work with this based on user defined units.
Eric
