Announcements
Convert Fusion 360 Design for eDrawings Viewer
Does anyone know how to convert a Fusion 360 design to a file version compatible with eDrawings viewer on Mac?
ekinsb
This forum is for the API and programming questions.  Are you wanting to use the API to automate this process?  There currently is not any API support for the Fusion 360 drawing functionality.  If you're not asking about using the API, then I don't know the answer.  I don't know what required to go to eDrawings but from a Fusion 360 drawing you can export it a DWG or PDF file.  I don't know if you can go to an eDrawing from that or not.  It seems like a PDF file would be more universal anyway.
Brian Ekins
Mod the Machine blog
