Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
constructionPlane problem
3 REPLIES 3
brad.bylls
181 Views, 3 Replies
In my add-in script I have created two construction planes to do some mirroring.
    planes = newComp.constructionPlanes
    constPlane = newComp.yZConstructionPlane
    planeInput = planes.createInput()
    offsetDistance = adsk.core.ValueInput.createByReal(0)
    planeInput.setByOffset(constPlane, offsetDistance)
    yzPlane = planes.add(planeInput)
After the mirroring is done I try:
    yzPlane.isVisible = False
and I get an exception error that says "can't set attribute".
I have also tried:
    constPlanes.isVisible = False
and get the same exception error.
IntelliSense shows "isVisible" is available for yzPlane and constPlane
Brad Bylls
3 REPLIES 3
kandennti
in reply to: brad.bylls
brad.bylls
in reply to: kandennti
Ok
Then how do you make them invisible?
Brad Bylls
MichaelT_123
Hi Mr BradBylls,
This seems to be the old trap. Consider familiarising yourself with https://forums.autodesk.com/t5/fusion-360-api-and-scripts/show-hide-jointorigin/m-p/9839486#M11771
and check isLightBulbOn. Who knows, it might work.
Regards
MichaelT
MichaelT
