Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Construction axes
0 REPLIES 0
Message 1 of 1
MichaelT_123
165 Views, 0 Replies
Construction axes
Hi TF360,
I have noticed with pleasure the new visual representation of construction axis lines. They are now as beautiful as those in AutoCAD 20+ years ago. Well done!
One issue, however, restricts me to reach even higher level of the excitation. It is the absence of API function allowing adjusting position of the lines ends.... similar to the function constructionPlane_var.displayBounds.
It shouldn't be overwhelmingly difficult to add such API for the enjoyment of many (few)... should it be?
Regards
MichaelT
MichaelT
0 REPLIES 0
