Connecting command created handler to command execute handler
pcajp96
pcajp96
Hi, I am new to fusion API and am trying to make a simple script that will take inputs from the user and output a propeller hub. I've been able to create the geometry and the dialog box but can't seem to connect the two together. I am using the work flow described on this page http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051 For some reason the user inputs do not connect to the geometry and no part is produced unless the values are defined in the Command Execute Handler. My code is posted below with the area of interest in green font. Any help or other examples of a UI customization would be greatly appreciated.
Thank you!
import adsk.core, adsk.fusion, adsk.cam, traceback
# Global list to keep all event handlers in scope.
# This is only needed with Python.
handlers = []
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        propButton = cmdDefs.addButtonDefinition('propButtonId',
                                                   'Create Propeller',
                                                   'Propeller button tooltip')
        # Connect to the command created event.
        propCommandCreated = propCommandCreatedEventHandler()
        propButton.commandCreated.add(propCommandCreated)
        handlers.append(propCommandCreated)
        # Execute the command.
        propButton.execute()
        # Keep the script running.
        adsk.autoTerminate(False)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    try:
        # Delete the command definition.
        cmdDef = ui.commandDefinitions.itemById('propButtonId')
        if cmdDef:
            cmdDef.deleteMe()
    except:
        if ui:
# Event handler for the commandCreated event.
class propCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        # Verify that a sketch is active.
        eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
        # Get the command
        cmd = eventArgs.command
        # Get the CommandInputs collection to create new command inputs.
        inputs = cmd.commandInputs
        des = adsk.fusion.Design.cast(app.activeProduct)
        inputs.addValueInput('outerDiameter', 'outer diameter', 'cm', adsk.core.ValueInput.createByReal(5.0))
        inputs.addValueInput('innerDiameter','inner diameter','cm',adsk.core.ValueInput.createByReal(2.0))
        inputs.addValueInput('height','height','cm',adsk.core.ValueInput.createByReal(1.0))
        # Connect to the execute event.
        onExecute = propCommandExecuteHandler()
        cmd.execute.add(onExecute)
        handlers.append(onExecute)
        # Connect to the inputChanged event.
        onInputChanged = propCommandInputChangedHandler()
        cmd.inputChanged.add(onInputChanged)
        handlers.append(onInputChanged)
# Event handler for the inputChanged event.
class propCommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.InputChangedEventArgs.cast(args)
# Event handler for the execute event.
class propCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.CommandEventArgs.cast(args)
        # Get the values from the command inputs.
        inputs = eventArgs.command.commandInputs
        unitsMgr = app.activeProduct.unitsManager
        OD = inputs.itemById('outerDiameter').value
        ID = inputs.itembyId('innerDiameter').value
        h = inputs.itembyId('height').value
        #There is something wrong with getting the values from the
        #CommandCreatedEventHanlder. When the values are defined as below it
        #works fine but nothing happens when the values are defined as above
        #OD = 6
        #ID = adsk.core.ValueInput.createByString('4 cm')
        #h = adsk.core.ValueInput.createByString('5 cm')
        createHub(OD,ID,h)
def createHub(outerDiameter, innerDiameter, distance):#def drawTriangle(baseLength, heightScale):
    doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
    design = app.activeProduct #what's open at the time
    # Get the root component of the active design.
    rootComp = design.rootComponent #sets up the top level component of the design in fusion
    # Get extrude features
    extrudes = rootComp.features.extrudeFeatures
    # Create a new sketch on the xy plane.
    sketches = rootComp.sketches #sketches comes from the object model(that big tree)
    xyPlane = rootComp.xYConstructionPlane # tell it to use xy plane
    sketch = sketches.add(xyPlane) #take sketches object and add it to the xy plane
    # Draw some circles.
    circles = sketch.sketchCurves.sketchCircles
    circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), outerDiameter/2)
    #get sketch profile
    prof = sketch.profiles.item(0)
    #distance = adsk.core.ValueInput.createByString('5 cm')
    extrude1 = extrudes.addSimple(prof, distance, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    # Get the extrusion body
    body1 = extrude1.bodies.item(0)
    body1.name = "Hub"
    # Get the end face of the extrusion
    endFaces = extrude1.endFaces
    endFace = endFaces.item(0)
    # Create a construction plane by offsetting the end face
    planes = rootComp.constructionPlanes
    planeInput = planes.createInput()
    offsetVal = adsk.core.ValueInput.createByString('0 cm')
    planeInput.setByOffset(endFace, offsetVal)
    offsetPlane = planes.add(planeInput)
    # Create a sketch on the new construction plane and add a sketch point
    offsetSketch = sketches.add(offsetPlane)
    offsetSketchPoints = offsetSketch.sketchPoints
    sPt0 = offsetSketchPoints.add(adsk.core.Point3D.create(0, 0, 0))
    # Create a hole input
    holes = rootComp.features.holeFeatures
    holeInput = holes.createSimpleInput(innerDiameter)
    holeInput.setPositionBySketchPoint(sPt0)
    holeInput.setDistanceExtent(distance)
    hole = holes.add(holeInput)
ekinsb
What you have is very close but just contains a few mistakes.  I think you would have found the mistakes yourself if you had added try except statements in each of your functions.  What's happening in your original code is that it's hitting a problem and failing without anything about the problem being reported because the assert is not being handled anywhere.  Here's a version of your program where I added the try except statements and also fixed the few problems in the code.
handlers = []
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _ui
        _ui  = app.userInterface
        cmdDefs = _ui.commandDefinitions
                                                   'Create Propeller',
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    try:
        if cmdDef:
            cmdDef.deleteMe()
    except:
    def __init__(self):
        super().__init__()
        try:
            # Get the command
        except:
    def __init__(self):
        super().__init__()
    def __init__(self):
        super().__init__()
        try:
            #unitsMgr = app.activeProduct.unitsManager
            ID = inputs.itemById('innerDiameter').value
            h = inputs.itemById('height').value
            createHub(OD,ID,h)
        except:
    try:
        #get sketch profile
        extrude1 = extrudes.addSimple(prof, adsk.core.ValueInput.createByReal(distance), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        body1.name = "Hub"
        holeInput = holes.createSimpleInput(adsk.core.ValueInput.createByReal(innerDiameter))
        holeInput.setDistanceExtent(adsk.core.ValueInput.createByReal(distance))
    except:
Brian Ekins
Mod the Machine blog
pcajp96
I tried to run this code and it does not seem to do anything. I'm not even getting an error message. I modified the original code to to have the syntax shown below and am now getting an error in the "ID = inputs.itembyId('innerDiameter').value" line. Is there an issue with using itembyId? Thanks in advance.
    def __init__(self):
        super().__init__()
        try:
            createHub(OD,ID,h)
        except:
            if ui:
Have you been able to solve this issue with getting itemById to pull the right information between the event handler and the execute handler? I'm having the same issue with a hole function.
I've tried multiple things, but I can't seem to be able to pull the points selected during the CommandCreatedEventHandler to populate as a list or array for use in the CommandExecuteHandler. See code below.
class HeatInsertCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # Get command
            # Get CommandInputs collection to create new command input
            # Create point selection
            points = inputs.addSelectionInput('points','Select Points', 'Select Hole Location')
            points.setSelectionLimits(0)
            points.addSelectionFilter('SketchPoints')
            # Create drop down menu with different inserts
            dropdownInput = inputs.addDropDownCommandInput('InsertDropdown', 'Select insert to be used', adsk.core.DropDownStyles.LabeledIconDropDownStyle)
            dropdownItems = dropdownInput.listItems
            dropdownItems.add('#0-80', True, '')
            dropdownItems.add('#2-56', True, '')
            dropdownItems.add('#4-40', True, '')
            dropdownItems.add('#6-32', True, '')
            dropdownItems.add('#8-32', True, '')
            dropdownItems.add('#10-24', True, '')
            dropdownItems.add('#10-32', True, '')
            dropdownItems.add('1/4-20', True, '')
            dropdownItems.add('M2', True, '')
            dropdownItems.add('M2.5', True, '')
            dropdownItems.add('M3', True, '')
            dropdownItems.add('M4', True, '')
            dropdownItems.add('M5', True, '')
            dropdownItems.add('M6', True, '')
            dropdownItems.add('M8', True, '')
            onExecute = HeatInsertCommandExecuteHandler()
        except:
class HeatInsertCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            ui.messageBox('In command execute event handler')
            product = app.activeProduct
            design = adsk.fusion.Design.cast(product)
            sketchpoints = inputs.itemById('points').value
            distance = adsk.core.ValueInput.createByReal(5)
            holeInput = holes.createSimpleInput(adsk.core.ValueInput.createByString('2 mm'))
            holeInput.setPositionByPoint(sketchpoints)
            except:
BrianEkins
I didn't try running your entire program but there's one problem I can see immediately with this line:
The itemById method returns a command input object.  In this case, it's a SelectionInput.  The SelectionInput object doesn't support a value property but supports other functionality that's appropriate for something that would do selection.  What you'll want to use is the selectionCount property, which indicates how many items have been selected, and the select method which takes an index as an argument and returns a specific selected item.
Brian Ekins
Thanks Brad!
However, shortly after posting this I figured out what the problem was.
What I needed to do was call the entity within the input and then call the index in the entity, as the code attached.
Where "sketchpoints" are the points selected during the EventCreatedHandler. Then, during the ExecuteHandler, I grabbed the selected sketchpoints using the inputs.itemById('points') followed by the selection index and entity.
    def __init__(self):
        super().__init__()
        try:
            pointCollection.add(sketchpoints.selection(i).entity)
            cutHoles(pointCollection, rootComp)
        except:
Cheers,
Nick
I figured it out!
You have to use .selection(index).entity!
Try
    def __init__(self):
        super().__init__()
        try:
            OD = (inputs.itemById('outerDiameter')).selection(0).entity
            ID = (inputs.itembyId('innerDiameter')).selection(0).entity
            h = (inputs.itembyId('height')).selection(0).entity
            createHub(OD,ID,h)
        except:
            if ui:
