Compute all parameters
mikko.husari
mikko.husari
I have a very parameter heavy design that gets its parameters via script. Part of my script fails after setting all necessary parameters, but can continue if I hit "compute all" from Modify menu (or ctrl+b). Is there a way to run that computation from API?
mikko.husari
Well, I figured it out a while a go but did not think about posting an answer as it was my own question.
This did the trick:
            adsk.doEvents()
esumft
Thought you might want to know you just saved someone's monitor from going out the window. 😁
mikko.husari
I really hope someone finds a better way as this is quite questionable. But, glad it did help 🙂
check this out: https://xkcd.com/979/
