Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Componet return 0 bodies
1 REPLY 1
raterWBBQB
173 Views, 1 Reply
Ptr<Profiles> profs = sketch2->profiles();
	Ptr<Profile> prof = profs->item(0);
	Ptr<RevolveFeatures> revolves = rootComp->features()->revolveFeatures();
	Ptr<RevolveFeatureInput> revInput = revolves->createInput(prof, sketchLine1, FeatureOperations::NewComponentFeatureOperation);
	Ptr<ValueInput> angle = ValueInput::createByReal(2.0*PI);
	revInput->setAngleExtent(false, angle);
	revolves->add(revInput);
	Ptr<BRepBodies> bodies = rootComp->bRepBodies();
	ui->messageBox(std::to_string(bodies->count()));
	if (!bodies) {
		ui->messageBox("bodies");
		return false;
1 REPLY 1
marshaltu
in reply to: raterWBBQB
From the piece of codes you posted, it may be because new body is created in a sub component. You have to pass "FeatureOperations::NewBodyOperation" as argument if you want the new body in root component.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
