Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
CommandControl index property bug
6 REPLIES 6
rolandas.vegis
391 Views, 6 Replies
index property of CommandControl object doesn't work correctly. After changing the order of controls in the toolbar, index property doesn't update - it shows the old index.
6 REPLIES 6
goyals
in reply to: rolandas.vegis
Please share the script so I can try on my side.
Shyam Goyal
Shyam Goyal
Sr. Software Dev. Manager
rolandas.vegis
in reply to: goyals
Here is the code and the screencast to show exactly what I mean.
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <CAM/CAMAll.h>
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
 app = Application::get();
 if (!app)
  return false;
 ui = app->userInterface();
 if (!ui)
  return false;
 const auto controls = ui->activeWorkspace()->toolbarPanels()->item(0)->controls();
 const auto sketch = controls->item(0);
 auto sketchId = sketch->id();
 auto sketchIndex = sketch->index();
 const auto rectangle = controls->item(2);
 auto rectangleId = rectangle->id();
 auto rectanglendex = rectangle->index();
 return true;
extern "C" XI_EXPORT bool stop(const char* context)
 return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
 switch (reason)
 case DLL_PROCESS_ATTACH:
 case DLL_THREAD_ATTACH:
 case DLL_THREAD_DETACH:
 case DLL_PROCESS_DETACH:
  break;
 return TRUE;
#endif // XI_WIN
rolandas.vegis
in reply to: goyals
Here is a screencast so you could better understand what I mean: https://autode.sk/2vVil8o.
And code:
	if (!app)
		return false;
	if (!ui)
		return false;
	return true;
	return true;
#ifdef XI_WIN
	switch (reason)
		break;
	return TRUE;
#endif // XI_WIN
goyals
I am able to see the problem you described. In my opinion index property serve very little purpose on ToolbarControl. If you are looking for a particular control in a toolbarpanel then search using its id then index. Let me know if there is any specific problem which can be solved using only index and not by its ID.
Shyam Goyal
Shyam Goyal
rolandas.vegis
in reply to: goyals
I was trying to save the position of my commands, so when re-running the addin Fusion would create them in the way user left them. Found a workaround using promotedControls collection. Thanks for your assistance.
goyals
I think it should be working by default. I just reordered few controls in a toolbar panel and restarted the Fusion. I found them how I left in my previous session so in my opinion it should be working by default for you.
Shyam Goyal
