Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Command Inputs API Sample Documentation has broken link to resources ZIP File
3 REPLIES 3
chris.monachanZWSCF
227 Views, 3 Replies
In the API documentation there is a Commands Inputs API Sample which contains a link to a zip file which contains resources used in the example. The link is dead and perhaps needs updating.
The resource sample is:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
and the link that doesn't work from the documentation is:
https://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/SupportFiles/CommandInputsResources.zip
Tags (3)
Labels (3)
3 REPLIES 3
Thank you very much for the file.
Should I "accept solution" to this do you think? It would be good to get someone in the documentation department to update the the link in the API for future people.
@chris.monachanZWSCF Thank you for reporting the issue. I have created a ticket with the concerned team to update the link.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
