Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Command handling setup - missing CommandEventArgs Object
4 REPLIES 4
kealan4LBW
150 Views, 4 Replies
I'm trying to call a command execute from a different event.py script but I'm struggling to get my head around the way the event handler objects and events are set up in the add-in examples.
Code below from the API examples:
From my very limited understanding, when the command_created() function is called by the initialisation function , it then in turn calls the futil.add_handler function, which creates a link between the  tigger event, which is the command.execute event of a adsk.core.CommandCreatedEventArgs object which the initialisation function created via yet another handler, and the resulting function that gets called, command_exectute()
def command_created(args: adsk.core.CommandCreatedEventArgs):
    # General logging for debug.
    futil.log(f'{CMD_NAME} Prompt user for product ID')
    # https://help.autodesk.com/view/fusion360/ENU/?contextId=CommandInputs
    inputs = args.command.commandInputs
    # TODO Define the dialog for your command by adding different inputs to the command.
    # Create a simple text box input.
    inputs.addTextBoxCommandInput('text_box', 'Some Text', 'Enter some text.', 1, False)
    # Create a value input field and set the default using 1 unit of the default length unit.
    defaultLengthUnits = app.activeProduct.unitsManager.defaultLengthUnits
    default_value = adsk.core.ValueInput.createByString('1')
    inputs.addValueInput('value_input', 'Some Value', defaultLengthUnits, default_value)
    # TODO Connect to the events that are needed by this command.
    futil.add_handler(args.command.execute, command_execute, local_handlers=local_handlers)
    futil.add_handler(args.command.inputChanged, command_input_changed, local_handlers=local_handlers)
    futil.add_handler(args.command.executePreview, command_preview, local_handlers=local_handlers)
    futil.add_handler(args.command.validateInputs, command_validate_input, local_handlers=local_handlers)
    futil.add_handler(args.command.destroy, command_destroy, local_handlers=local_handlers)
Then going into the add handler function to see what the handler looks like:
def add_handler(
        event: adsk.core.Event,
        callback: Callable,
        name: str = None,
        local_handlers: list = None
    """Adds an event handler to the specified event.
    Arguments:
    event -- The event object you want to connect a handler to.
    callback -- The function that will handle the event.
    name -- A name to use in logging errors associated with this event.
            Otherwise the name of the event object is used. This argument
            must be specified by its keyword.
    local_handlers -- A list of handlers you manage that is used to maintain
                      a reference to the handlers so they aren't released.
                      This argument must be specified by its keyword. If not
                      specified the handler is added to a global list and can
                      be cleared using the clear_handlers function. You may want
                      to maintain your own handler list so it can be managed
                      independently for each command.
    :returns:
        The event handler that was created.  You don't often need this reference, but it can be useful in some cases.
    module = sys.modules[event.__module__]
    handler_type = module.__dict__[event.add.__annotations__['handler']]
    handler = _create_handler(handler_type, callback, event, name, local_handlers)
    event.add(handler)
    return handler
def _create_handler(
        handler_type,
        callback: Callable,
        name: str = None,
    handler = _define_handler(handler_type, callback, name)()
    (local_handlers if local_handlers is not None else _handlers).append(handler)
    return handler
And then the actual execute function definition, which needs to be passed a CommandEventArgs object so it can use the object to collect the inputs from the dialog boxes using the .command.commandInputs properties, presumably.
def command_execute(args: adsk.core.CommandEventArgs):
    futil.log(f'{CMD_NAME} Command Execute Event')
    # TODO ******************************** Your code here ********************************
    # Get a reference to your command's inputs.
    text_box: adsk.core.TextBoxCommandInput = inputs.itemById('text_box')
    value_input: adsk.core.ValueCommandInput = inputs.itemById('value_input')
    # Do something interesting
    text = text_box.text
    expression = value_input.expression
    msg = f'Your text: {text}<br>Your value: {expression}'
    ui.messageBox(msg)
My problem is when I try to call this command_exectute function from another function in another script, I don't know what CommandEventArgs object to pass to it, if I pass it nothing, I get an error about missing args. I've managed to pass it the CommandEventArgs class instead of an instance of the class, which also didn't work.
I can't see where the event handler is creating the instance of the CommandEventArgs object, or passing any object to the execute function.
Do I create a new commandeventargs object in my other py script and pass that do the execute function or do I need to find a pointer to the object that the event handler made and pass  it that instead, or does it matter?
I'm struggling to wrap my head around how this is working.
4 REPLIES 4
kandennti
in reply to: kealan4LBW
Hi @kealan4LBW -San.
Isn't it difficult because you are trying to call the command_exectute function from another script?
Wouldn't it be better to put what you are currently doing in the command_execute function in a separate file and call it from two different scripts?
kealan4LBW
in reply to: kandennti
That c9mmand execute function is straight out of the API example docs, I haven't changed it, all I'm trying to do now is call the function to make the box appear but I can't even get that to work
BrianEkins
You execute a command by getting the CommandDefinition of your command and calling the execute method. This results in Fusion firing the commandCreated event. You get a CommandDefinition by using the UserInterface.commandDefinitions.itemById. When you create your command, usually using the CommandDefinitions.addButtonDefinition method, you provide the ID for your command. That's the ID, you'll use in itemById.
Brian Ekins
kealan4LBW
It works! Thank you Brian.
The commandDialog example has this command definition:
cmd_def = ui.commandDefinitions.addButtonDefinition(CMD_ID, CMD_NAME, CMD_Description, ICON_FOLDER)
And then from my second script, I've got an import of the example py file and just called
from .. import commandDialog
commandDialog.cmd_def.execute()
and its firing the event and displaying 🙂
